The surface under this folder will not be visible
rcentenoU3KHH
rcentenoU3KHH
Hi masters, newbie here. I cant find my inserted polyface named Red_0 to -1_North Crossing
when I click yes this what I got.  Please help. Thank you
Accepted solutions (3)
Replies (9)
lim.wendy
Hi Robert,
Welcome to the InfraWorks forum!
It sounds like you might be dealing with an issue related to surface categorization. If the surface was imported from Civil 3D, please try the following steps:
  1. When the message about uncategorized surfaces appears, select "YES."
  2. Open the Surface Layers dialog to categorize the data.
  3. Enable visibility for any Uncategorized terrain surface layers.
  4. Move them to the Ground Surface or any suitable category.
Note: This notification is a new feature introduced in Autodesk InfraWorks to help with the import process. It alerts you when surface data is not categorized and provides an option to open the Surface Layers dialog for categorization.
Let me know if this helps or if you have any further questions!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @rcentenoU3KHH ,
InfraWorks can only have one "terrain" surface. You can add multiple data sources for terrain, but you need to tell the program if they should be merged with the existing terrain. If yes, drag them to "ground surface".
It is possible to have them displayed separately without merging into existing terrain. Then right-mouse click "new surface layer", enter a name and drag the surface to this layer.
If you don't want to have the new surface have any influence to the model, keep it in the "uncategorized layer".
See also: Help | To add or modify surface layers
Karsten.
Karsten Saenger
rcentenoU3KHH
In my Data source I can not change the Type: Terrain. The dropdown is freeze. how to make the dropdown function?
rcentenoU3KHH
How to make the Type: Terrain dropdown function? its freeze
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @rcentenoU3KHH ,
the data source is configured to be a terrain automatically. Once a data source has a type assigned, you cannot change it anymore.
Everything I said before was regarding the InfraWorks Layers and not the Data Source Configuration. You showed the Layers in your first message.
Karsten.
Karsten Saenger
rcentenoU3KHH
Thank you for your help Karsten I but cant work. The red crossing that I want to insert on both sides just go back and fort from left to right. Is it ok if I pass you the file and help me out? Please?
rcentenoU3KHH
I got it now Karsten, but how can I change the color individually? Whenever I change the Individual XML the other follows
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @rcentenoU3KHH ,
the color of a surface layer can be changed by right-mouse-click on the surface layer (->"south").
Karsten.
Karsten Saenger
rcentenoU3KHH
@Karsten.Saenger you dont know how thankful I am with your teaching... I did it... Thank you master @Karsten.Saenger
