The Intersection misses bridges?
mattlee1111
Message 1 of 14
mattlee1111
I got 2 problems
1.I create a interchange,then the 2 lanes become 3 lanes in the intersection.But the bridge disappear in the intersection??
2.in order to solve first problem,I add the bridge in the widening zone,But the bridge deck didn't attach the lane??
Replies (13)
Message 2 of 14
TomislavGolubovic
Just tried this, works ok for me? I'm on 2017
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 3 of 14
mattlee1111
Thanks for help.I already upgraded infraworks 2017.but the problems still existed...
The 2nd question--->
When I widen a lane in the transition,then Add bridge in the transition,
The bridge won't follow the route in curve zone of the transition
for extreme example
Message 4 of 14
elliott.rosenfeld
Once you select the bridge, select a girder group and set the “Girders in plan” parameter to curved in the Girder Group stack panel.
I think that will resolve the transition issue you are showing. Please let me know if this gets you what you are looking for!
Elliott
Principal Specialist, Infrastructure
Message 5 of 14
@elliott.rosenfeld shouldn't it be better if the girders will automatically follow the bridge? Is it something that we should request through an idea?
I got the same results when creating a bridge with a curve.
P.S. I cannot find the girders in plan. Are you using the Rolling Sandbox?
Thank you
Message 6 of 14
Eduardo.Soethe
You can put on Idea station!!
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
Message 7 of 14
Thank you! Done 😃 Let's hope
Message 8 of 14
mattlee1111
I set the “Girders in plan” parameter to curved in the Girder Group,but it still didn't work??
Message 9 of 14
elliott.rosenfeld
Hey there,
That's too bad, i wasn't expecting that result. Let me check with the bridge team to see if there are any bridge curve limitations built-in. Also, if you are able to share you model with me I would be happy to take a look as well. You can direct message me to share your model.
Elliott
Message 10 of 14
mattlee1111
Thanks~
I will send message to you for sharing my model.
Message 11 of 14
I'm new to using Infraworks but I think I might know what your problem is for your 1st pic.  I had the same issue and what I noticed was that you On Ramp is not a bridge.  Try making the On Ramp a bridge for a small section.  I think that because the On Ramp has grading the coding is trying to add the grading to the intersection and that is why your bridge intersection is missing.
Message 12 of 14
mattlee1111
I try to change the ramp from a embankment to a bridge ,but it still miss the bridge in the intersection
I think the problem is -->use widening to add a lane ,it will miss the bridge in the widening zone~
Thanks for your advices~
Message 13 of 14
ara.ashikian
We are aware of issues in modeling bridges at intersections. We will be investigating different possible solutions.
-Ara
PM InfraWorks 360 / Bridges
Ara Ashikian, P.Eng.
PM Bridges / Civil Structures
Message 14 of 14
This still seems to be an issue -- using 2018 version. Also to the right of that, is there a way to include the barrier in an intersection? Maybe I knew this once and forgot that skill to learn a new one...?
Bridge Deck/Girder Issues - IW 2018Bridge Deck/Girder Issues - IW 2018
