Hei, I have a problem with selecting the terrain holes that I make in infraworks. Once created I can no longer select it or modify/delete it as the rest of the coverage areas I create. Is there any option that allows to modify them? I've seen this problems with IW360 2016 and 2017, not before.
I have always been able to modify this kind of coverage areas.
Óscar
Solved by Karsten.Saenger. Go to Solution.
Hello Óscar,
you should be able to select the terrain holes - created as coverage - with dragging the mous pointer over the border. It will highlight and you can select it.
Karsten.
Hello Karsten, thanks for the reply.
It is the type of hole that is in the folder Material/Terrain from the catalog. I send a snapshot of it. I cannot select it as you say, no matter what I do. It doesn't highlight.
It is a little frustrating 😉
Óscar
Hi Óscar,
I see what you mean and can re-create the problem.
I will discuss with the developers if this program behavior is "as designed".
In the meantime I have recorded a workaround: http://autode.sk/2d68pyr
-> Edit the terrain hole style to a color. After this you can select the coverage again. Once you are done, just switch it back to the previous style.
If you just want to switch the terrain hole on or off, this can be done in the surface layers.
Karsten.
Hei Karsten!
Thanks a lot. That resolved the issue perfectly.
Kind regards,
Óscar
How do I remove the terrain hole border. It also has rounded edges that I would like to make square.
