Surface Layers Names missing in 2027 release?
John_de_Leeuw-NTI
Advisor Advisor
Message 1 of 12
John_de_Leeuw-NTI
@Karsten.Saenger can you confirm?
John de Leeuw
Senior Consultant
Community Ambassador - Twitter - LinkedIn
Replies (11)
Message 2 of 12
Alfred.NESWADBA
when opening the "Roads Tutorial" I can see this (screenshot), therefor part "Ground Imagery & Coverages" is not empty / does show names, at least not within this project:
Maybe this depends only on a specific project?
However, I have other issues in AIW 2027 like data from model builder can't be opened (local data) with the first click, I have to select the project (after generated by Model Builder) multiple times before I can open the model without error messages. Seems like 2027 needs a service pack because of multipe reasons.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 12
John_de_Leeuw-NTI
@Alfred.NESWADBA Thats not the Surface Layers but the standard Data Sources Panel.
John de Leeuw
Senior Consultant
Message 4 of 12
John_de_Leeuw-NTI
@Alfred.NESWADBA Sorry my mistake, it is actually. Have to try the sample project then.
John de Leeuw
Senior Consultant
Message 5 of 12
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @John_de_Leeuw-NTI , @Alfred.NESWADBA ,
I can recreate issues with the surface layers. Not exactly the same as you showed, but also empty and/or duplicate layers.
I can't recreate any issue with opening new Model Builder models. Can you find any error in the log file (%AppData%\Autodesk\Autodesk InfraWorks\logs%AppData%\Autodesk\Autodesk InfraWorks\logs)?
I will create a support ticket for the layer issue and continue testing both issues on other PCs.
Karsten.
Karsten Saenger
Message 6 of 12
John_de_Leeuw-NTI
Hi @Karsten.Saenger I will look into the logfiles later today. I do use custom feature categories quite a lot. Maybee you can test that aswell. So put imported Surface Layers on your custom catagories and see if any problems with the names happens. I did not yet try to create a fully new model with custom categories but will also try that.
John de Leeuw
Senior Consultant
Message 7 of 12
Alfred.NESWADBA
Hi Karsten,
Send it via PM within a few seconds.
- alfred -
Alfred NESWADBA
Message 8 of 12
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Alfred.NESWADBA ,
I answered your private message....
Karsten Saenger
Message 9 of 12
Karsten.Saenger
Autodesk Support
Autodesk Support
our developers have confimed an issue with the surface layers in InfraWorks 2027. They are in the process of fixing it.
Unfortunately, I don't have a target date for the fix yet.
Karsten.
Karsten Saenger
Message 10 of 12
John_de_Leeuw-NTI
Thanks for the confirmation and update @Karsten.Saenger
John de Leeuw
Senior Consultant
Message 11 of 12
lbobariu
similar issue here with TIF files
Message 12 of 12
m_kingdon
I have the same problem with coverage areas on multiple projects.
Mike Kingdon
Civil 3D Zealot
