I have an issue when importing a surface into Infraworks. I used the Model Builder to create my model. When I try to import a surface into my model, it does not show up. I am using the same coordinate system in both the model and the surface (CA83-VF).
When I load the surface by itself in a new model it does I can see the surface.
I tried using both LandXML and IMX export files with the same results. I have installed all the updates for 2019 on both Infraworks and Civil3D.
I have tried several of the workarounds but still not luck. (export it back into civil 3D, use regular AutoCAD, DXF)
Any suggestions on what should I try next? Attached you guys can find the surface file.
Solved by ToddRogers-WPM. Go to Solution.
This is a little unrelated, but see if this fixes it...
That link was very helpful! I was able to fix my issue by dragging my troubled layer from the categorized section to the terrain section and it worked.
Thanks!
https://knowledge.autodesk.com/community/screencast/762fc864-f2de-48b0-bd15-3071771160e8
