surface disapear
surface disapear
namlt33
surface disapear
namlt33
the 1st picture showing Infarawork existed surface, the 2nd show my civil3d imported surface. As you can see, my surface is missing some are while the civl3d surface is completely fine. This issue happend with all of my model but i dont know how to fix it.
Todd_Rogers
You should keep both of them turned on.
Todd Rogers
Infrastructure Administration
namlt33
i had try to but still those are not display the BMTH are correctly. Recently i found that the coverages causing the same problem. One i drape an .shp file the surface get broken
