Style multiple Terrain Models
Hi all,
Is there a way to style different terrain models independently from one another; basically I have connected a ground surface model (.asc file) and have flood levels in another file (again .asc) but when they are put in the same model whenever I create a terrain theme is applies to both the existing ground and the flood levels. Is there a way to style them independently from one another?
I thought I might be able to do this based on the surface layers but no such luck.
thanks
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
this is a product limitation, unfortunately.
Terrain themes are applied to all surface layers.
I suggest to create a product enhancement idea on forums.autodesk.com/t5/infraworks-360-ideastation/idb-p/129
Karsten.
Karsten Saenger
roskirko
Perhaps you can try this : Place the flood model elevation data into its own Surface Layer category other than Ground Surface. For the flood category, set the style to the Water Shader style.
Geographic Information Systems
Fanshawe College
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @roskirko ,
excellent, this workaround seems to work:
  • Terrain themes is applied to all surface layers
  • But the water shader material overwrites it
This image shows a terrain surface layer with terrain themes and an additional surface layer below with water shader:
Karsten.
Karsten Saenger
