Hey @egil.rasmussen!
This is a pipeline created by the command "pipeline", right? The reason I asked this, if you create a "drainage network" with pipelines and structures, the pipeline properties come a little different.
As you can see, InfraWorks calculates the slope and update it if you change the start or end inverts. Therefore, I advise creating this drainage network to better evaluate the properties. If the structures are not important, you may delete them.
Clicking on the blue cone for pipelines gives you the elevation but this is info from that point, therefore there is no slope. If you change it IW crashes for pipelines created both from "pipeline" and "drainage network"...this may be solved in updates.
Best regards,
[PT-BR] Se essa postagem foi útil para você, clique em
Curtir! Se a resposta resolveu o seu problema, clique em
Aceitar Solução. [EN-US] If it was helpful to you, click on
Like! If the answer solved your problem, click on
Accept Solution.
Matheus Lima Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager |
Instagram @bim_infra |
LinkedIn
