Simple alignment style
dave_lawrence
Alumni Alumni
Message 1 of 1
dave_lawrence
If you want to display your roadway alignments as simple solid colors this can easily be accomplished in InfraWorks
  1. In the Style Pallet under Material Group, select one of the material groups and duplicate it
  2. Once duplicated modify the materials to match what you need
  3. Next open up the road styles pallet. duplicate the asphalt road
  4. Edit each new road styles to point to the new material group you made
  5. Then set the track top of surface to the alternative that corresponds to the road style.
  6. once you have grated all your styles you can apply them to your road alignmentsroutes.PNG
  7. Don’t forget to save your styles so that you can import them to be reused.
Dave Lawrence
Replies (0)
