Show shape attributes as table in model
Hi
Is it possible to show attributes from a shape file as a pop up table in the model.
BrianHailey
What do you mean by a "pop up table"? As in, pop open a window that shows all the data attributes in the table or as in, hover your mouse over an object and have it pop up a table showing specific data?
You can accomplish the second option by applying tooltips to the objects with the data you want to see.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
I would prefer to have a name hovering over it when I get within a certain
distance and then be able to click this name or hover the mouse over it to get the
full table of information from the attributes of the data source.
But any way of getting the attributes to show in the model would be great.
Another thing I would like to achieve, is to assign different styles on data within the same data source
depending on the attributes within the source.
Thanks for the reply!
Gunnar Fjogstad Hansen
COWI
Btw, when you say I can get the second option from tooltips.
Do you mean that I can add them manually or do you have a way to pick up and show the attributes of the data source as a tooltip?
