Help! I have an area where there are 3 bridges - 1. short bridge over roadway 2. long bridge over rail 3. short bridge over an interchange ramp. The middle bridge is where I am having issues. When I try to put the longer, middle bridge in, the barrier stretches across the roadway and doesn't tie in properly, (I think because the bridges are so close together). As a work around, I decided to copy the roadway style I was using and just add barrier, to give it the bridge feel. I then added a zone where the bridge will be, using the new style. This appeared to work as far as everything tying in nicely, accept the roadway is highlighting in green now. See attached image. Anyone know why?!?
Solved by Matt__W. Go to Solution.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Here's a short Screencast showing what happens to an intersection when the intersection material is removed and the default material (in this case, the color green) is used. It looks like exactly what's happening in the image you posted.
Matt Wunch
Twitter | LinkedIn
