Roads>component road
Hi, i drew a road then i clicked convert to component road after that command there appear a few loop point such as on picture which i added in post. How can i solve that problem. Thank you.
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
I haven't seen that before. It looks as if the road is twisted around, but the image is to small to say more.
Is it possible to share the model? To share a model create a zip file (with extension .rar or .7z) of the "model.sqlite" and "model.files" folder.
Karsten.
Karsten Saenger
I cant load file here beacuse of its size. So i uploaded google drive you can download from link.
https://drive.google.com/open?id=1afsKN7t79w5xlSn3AYn-NwqIE-YroGwx
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
thanks for sharing the model.
The reason why you see such strange component roads display is because the road centerline goes back and forth at these locations. It's difficult to see, but here is a screenshot showing the vector:
It's interesting why these "kinks" are created as there is a straight road before.
I will forward this behavior to the development team for investigation.
Karsten.
Karsten Saenger
