- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having troubles with importing revit models into infraworks. After selecting the revit model to import and having the "uploading file bundle to cloud" data operation take place, the revit file shows up in the data sources. However, when I go in to configure, and click on the 3D Model tab, the preview is blank. I have previously used the "interactive placing" button to place in the model. Usually the revit model shows up and can me moved about for placement during this operation. Now, I just get a little yellow cube. After clicking to place, and clicking close and refresh, a "Data Source Operation Failure" message pops up. It says the refresh failed for the reason "The bounding box of data source is invalid of the data source is empty"
I have previously successfully imported this exact Revit model into this same Infraworks model, so I am not sure what has changed, and why it will no longer import. It appears like the cloud processing of the revit fail may not be working properly/is failing.
