Hey everyone, I just got a new much more powerful computer. However, the new computer is having WAY more issues with Infraworks. Now whenever I zoom in to do detail work I get the below error - even when I turn my model detail and rendering settings all the way down. Anyone have a solution?
Solved by andrewofabley. Go to Solution.
Solved by ToddRogers-WPM. Go to Solution.
Did you reduce the display settings in the Application Options?
Did you by chance change to new ultra high Def display?
What are your new machine specs?
Laptop or Desktop?
https://www.hp.com/us-en/shop/pdp/omen-17t-ck000-laptop-2y4b1av-1
I ended up with the OMEN 17t-ck000.
For both @andrewofabley and @ToddRogers-WPM - In the end the designer had a custom barbwire fence decoration that was super dense and blowing up the model. Once I got the fence poly count reduced we were back to up and running. As always, thank you both for the response!
That's good to hear, and a relief that I made a good choice haha! I tried to put some research into what I wanted. So far, I am loving it too! So nice to have so much power in a laptop....AMAZING.
