Problem moving a coverage area on top of another
ml2WW4U
ml2WW4U
I  am trying to bring a coverage area on top of another coverage area.
Is there a way in Infraworks to do that, similarly to Autocad's "Bring to Front"?
Thanks in advance
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @ml2WW4U ,
did you create the coverages yourself (sketched) or did you import polygons?
Karsten.
Karsten Saenger
ml2WW4U
I created them myself.
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @ml2WW4U ,
that explains it. Sketched coverage features are all put on one layer. It's not possible to change the display order of them afterward.
If you import polygons to create the coverages, each imported feature is put on a separate layer and it is possible to change the display order by dragging the layers into a different order.
Karsten.
Karsten Saenger
ml2WW4U
Thanks a lot 🙂
