InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Problem importing corridors from Civil 3D
2 REPLIES 2
Irena.antolin
452 Views, 2 Replies
I have trouble importing corridors into Infraworks using the command import Autodesk Civil 3D DWG.
In Civil 3D I have a corridor consisting of several baslines at an intersection (Picture 1), but in Infraworks, there are space between centerline basline and edge baselins (Picture 2).
I have InfraWorks 2021.1 and Civil 3D 2021.1.1
Picture 1:
Picture 2:
Any help or ideas would be greatly appreciated! Thanks in advance!
Labels (1)
2 REPLIES 2
FrankHuang
in reply to: Irena.antolin
@Irena.antolin  From the image, seems the alignment geometries are changed during the import process. could you please check geometries of those alignments?
There is a known issue if alignment contains floating curve and spiral.
Hope helps,
Frank Huang
Autodesk Infrastructure Product Owner.
"https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png"
Hi @Irena.antolin ,
here is the help documentation about curve geometry limitation:
About the Behavior of Alignment and Profile Entity Types when Exchanging Data Between Autodesk Civil...
Karsten
Karsten Saenger
Rail Community
