Offset Bridge
Offset Bridge
sduffin
Message 1 of 13
Offset Bridge
sduffin
I have a component roadway and I have added a bridge.  We want to illustrate the bridge being built on only the south half of the bridge.  However the bridge modeler wants to center it under my roadway (see attached PDF).
The component roadway is showing only 1/2 of the future roadway (South half).  Do the experts know of any way to simply offset the entire bridge from the roadway center line to accomplish this?  If not, what other suggestions are there?
Since it wants to center it under the component roadway cross section I thought about modeling the full width but don't know how to peel back and only show the intermin half-built roadway while still showing the full-width piers and maybe even the girders.  Is there a way to apply a transparent material to some of the roadway components so it shows through to the bridge?
Is there a way to export the bridge as a 3-d model and then re-mport it int the correct location as a DAE model or some other format?
Any help would be greatly appreciated as I am trying to get something prepared for a major proposal interview on Monday!!!
Thanks in advance for your help.
Accepted solutions (3)
Replies (12)
Message 2 of 13
elliott.rosenfeld
Just reading really quickly here -- I'll make sure to loop back and provide you with a detailed response. But for starters, have you tried to Toggle Bridge Deck transparency on/off? That really quickly hides the entire bridge Road/Deck to show the girders, piers, foundations, and abutments below.
  • Click to toggle bridge deck transparency.
Elliott
p.s. I'll loop back shortly!
Principal Specialist, Infrastructure
Message 3 of 13
elliott.rosenfeld
Sorry for my quick response earlier, I was running between meetings but still wanted to provide you with something.
Here's a bit more information, inline in orange.
Elliott
- Just to confirm, from looking at your bridge, by "south half", do you mean half the width of the bridge? (can't tell cardinal directions from your attached PDF).
I'm not certain if there is a way to offset the entire bridge. However, you could try creating your own Road/Deck styles in the Road/Street/Bridge catalog of the Style Palette, and manually adjust the roadway to be narrower than the bridge, similar to what is shown in your example.
Toggling Bridge Deck transparency is one option, but it will remove the entire Road/Deck from visibility. However, there definitely are ways to apply transparent materials to roadway components. For starters, take a look at this help topic, which explains the process of applying transparent materials to materials in your Roadway material group. http://help.autodesk.com/view/INFMDR/2016/ENU/?guid=GUID-601ED0C0-9B5A-4B40-85BA-FC872295F73B
You can export the bridge to IMX and open it in Civil 3D, which will recognize the bridge as 3D solids (individual bridge components are separate elements). However, InfraWorks 360 will not recognize this as a bridge when re-imported. See this help topic for more information: http://help.autodesk.com/view/INFMDR/2016/ENU/?guid=GUID-CA5B78BB-9D36-4F52-A840-41D4BBA09C87
Keep the questions coming! If i haven't identified a suitable solution for you, I'm happy to check back over the weekend and answer any questions that I can.
Message 4 of 13
sduffin
Thanks for the quick feedback! I think the material transparency option will work perfectly to solve my problem. The first screen shot (in attached PDF) shows the full-width roadway with the right half having all transparent materials applied so all you see is the deck below the roadway. Now if I can only get the concrete deck to go away on the right side (transparent) then I will have accomplished exactly what I needed to. The second screenshot (in attached PDF) is with the deck toggled off per your suggestion. This shows what I generally want under the bridge to show but with only the left half of the roadway and the entire bridge showing. As an option for the right side it would be even better if I could get the girders on the unbuilt road (right side) to disappear but keep showing all the piers) on the entire bridge. Once again the left side should show the bridge structure and the roadway. I have commented on the attached PDF which should hopefully clarify my desired outcome.
Hopefully this makes sense! Any suggestion on how to make the right side concrete deck below the roadway disappear will be huge!
Thanks for your help with this. Greatly appreciated!!
[cid:[email protected]]
Message 5 of 13
sduffin
I have worked on it more this morning and I have the ultimate bridge about where it needs to be, along with the roadway over the bridge shown correctly on the left side, and the roadway on the right side of the bridge shown with all transparent materials.  The interim roadway leading up to the bridge is also shown correctly with the left (south) half built and the right (north) half only graded (shown with a sand texture).  The attached PDF depicts this more accurately.  I feel like I am getting close but need to accomplish the following to finish it off:
Make the concerete deck on the right hand side of the bridge transparent so we can see the piers and girders only, while the left hand side of the bridge should show the full build-out -- roadway, sidewalk, curb and gutter, barriers, and the bridge structure (piers, girders, caps, etc.).  Even better is if I can show only the piers (and not the girders) on the right hand side of the bridge.
Any help on accomplishing the above would be greatly appreciated!  I can see success just around the corner....
Message 6 of 13
elliott.rosenfeld
 Hi there,
So i think you will be able to accomplish by setting the Deck material to a transparent material.
This can be accomplished by editing the material group that your bridge is mapped to.
1) open the Material Group tab  in the Style Palette and then edit the Concrete Bridges material group.
2) change the Bridge Bottom material to Colors > Transparent.
That's it!
Message 7 of 13
sduffin
That worked perfectly!  Attached is a PDF of the bridge with the transparency applied. The first two pages show the bridge from a few different angles. The third page shows it from the side and identifies one other minor thing that would be nice to adjust if it is possible.  It appears that when I rotated the piers that outside girders are fixed in lenght and do not show properly.  Do you know of an easy way to fix this?  If not I can live with this.
Thanks for taking the time to research this for me.  This is important and this is exactly what I need!!
Message 8 of 13
elliott.rosenfeld
You're welcome! Glad we were able to find a solution for you. As for the outstanding issue of girder length, I believe that can be controlled by the deck continuity settings. By default the bridge uses an arrangement that is not fully continuous across spans. You may want to modify the bridge deck continuity to see if this will get the result you're looking for. Take a look at this topic and let me know if that helps! https://knowledge.autodesk.com/support/infraworks-360/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Message 9 of 13
elliott.rosenfeld
Oh also, you can modify the bridge pylon material to be transparent, and I think that will hide your girders. I am away from my workstation but I can test that out shortly
Message 10 of 13
sduffin
Changing it to continuous for deck and girders looks a little better. Thanks!
Message 11 of 13
sduffin
Another hopefully question with a simple answer.  I am trying to change my component roadway so that the striping is yellow down the middle and would like a soild strip on the right had side (per the PDF).  is there an easy way to do this?  At a minimum I need the center line striping to be yellow  (and solid possibly)?
Thanks!
Message 12 of 13
sduffin
One other question about component roads and striping.  I would like to have either a solid or dashed yellow line in the center of the road (currently dashed white), and a solid white lane on the right side of the road (instead of dashed white). Is there a way to do this with a component roadway?  I tried messing with material groups and materials but still struggling to figure this out!
See attached PDF.
Thanks!
Message 13 of 13
sduffin
FYI I solved it by using a 0.33' wide lane and coloring white for the outer striping, and using the place objects to place a 3d model of the dashed yellow centerline. See 2nd page of attached PDF.  If anyone has a better way to do it I would love to hear it!
