Oculus Remote Controller not Working in Infraworks
subditadps
subditadps
Hi, is there any chance or way that i can use the remote controller to move in the Infraworks Oculus experience? I really need this for the big presentation. Thank you.
mzjensen
Hi @subditadps,
As far as I know, the only way to navigate around is to use the keyboard. Unfortunately I have not found a way to use the controllers.
Zachri Jensen, PE   |
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @subditadps ,
the Oculus Rift functionality is limited in InfraWorks, unfortunately.
Please see the link to learn what's possible:
Using Oculus (DK2) with Autodesk InfraWorks
Karsten.
Karsten Saenger
Owackenreuther
Here are the available IW keyboard keys, even for VR:
https://knowledge.autodesk.com/support/infraworks/learn-explore/caas/CloudHelp/cloudhelp/ENU/InfraWo...
I'm wondering if there is a way to map between Oculus and standard keyboard keys?
Key Action
W - A - S - DMove forwards - Left - Backwards - Right
B or SpaceJump to the next available bookmark
NEnable/disable stereoscopic projection (stereo mode)
VStart/stop playing storyboard (play again from beginning)
Shift + VStart/pause playing storyboard (continue playing at last position)
RRe-center view (re-orientate camera position to HMD orientation)
GAlign head with gravity
Shift + GAlign head with vehicle
