I have Infraworks 2020 downloaded, I created a new model as I did with earlier versions, but this new model has a model builder icon in lower right corner and when I click on the model to open it, the error reads, "Unable to open Model", how do I delete this model and start a new one?
Solved by SethHall. Go to Solution.
Hi @Anonymous
Did you click on the model tile and try again to open it? Try closing down InfraWorks, reopen, and let all the model tiles load. Then try clicking the tile again.
Hi @Anonymous
Where do you have your "cache location for cloud models" path set? Set it to your C drive and try opening it again.
OK, thanks for verifying.
Let's try this, send another model request (with a different name) and see what happens. Also if you could grab the tracking number, we can look make sure everything is good on it's path through Model Builder.
Also, what version of IW are you using?
The model is deleted from the cloud (model builder icon) once it has been opened. If the model is unable to be opened, it can't be deleted by the user as far as I know. I can pass that along to the team that deals with the cloud storage of the models and see if that is something they can address.
As for the two model icons, the only one that should be there is the "house". Try refreshing the model list and see if the original disappears.
