InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Model too big. How to purge it?
6 REPLIES 6
rc_maccord
4595 Views, 6 Replies
rc_maccord
I have a model that became too big for the group of students keep working. I wanted to divide the model in several groups, but to delete the unused objects.
I managed to duplicate and delete the unused objects (since each group was a different proposal). But the model is still to big. It only diminished from 3.54 Gb to 3.29 Gb.
I deleted the objects from the Style Palette and  and the Imported Data Sources, and yet, the file continue with 3.29 Gb.
How do I purge the unused files? (the inital file had 128 Mb)
Tags (2)
6 REPLIES 6
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @rc_maccord
it is normal that a model grows in size over time. It is the way how the model data is handled in InfraWorks and GIT and SQLite database - nothing gets lost.
For example, if you have a large point cloud dataset in the model and you remove it from the data sources, it's still existing internally.
A model cleanup tool was implemented to remove such data from the database some versions ago:
It's currently the only way to clean the models and reduce file sizes.
Karsten
Karsten Saenger
Hi @rc_maccord
Karsten
Karsten Saenger
rc_maccord
Hei Karsten,
I tried the Cleanup Model, but I don't have a Cloud Point import. I'm using the Model Generator. So it didn't have any effect.
The model growed bigger because the students imported a lot of objects (Sketchup and Revit), but when I delete these objects from the Data Source and from the Style Palette, the model don't get smaller.
Is there a way to diminished it?
Hei Karsten,
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @rc_maccord
could you please double check the following:
  • Are there any any large files put directly in the .files directory?  These could have been included in the git commit, which would cause the model to stay big
  • How big are the directories under the "Resources" folder?  If it is mostly TerrainTextures, reducing the image resolution may help with model size
Karsten.
Karsten Saenger
Hi @rc_maccord
Karsten.
Karsten Saenger
elliott.rosenfeld
Hi there,
Here are some pointers on how to improve performance in a large model:
http://autodesk.typepad.com/bimagination/2015/12/best-practices-for-extra-large-models-in-infraworks...
Elliott
Principal Specialist, Infrastructure
Hi there,
Elliott
BushW
in reply to: rc_maccord
BushW
Hello @rc_maccord
I'm just checking in to see if you need more help with this. Did the replies of @Karsten.Saenger and @elliott.rosenfeld provided work for you?
Please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Hello @rc_maccord
Best Regards,
Wendell
Wendell Bush
rc_maccord
in reply to: BushW
rc_maccord
Hey Karsten,
Sorry for not answering before. I had a lot to do and few time. I managed to diminish the model size a little.
We found another solution to our problem, which was to separate the model into different files (one for each group).
The biggest problem was that the students were uploading tons of files, and if someone tried to sync to download the changes, the volume had already increased too much. When we separated then, each group stopped to interfere with each other.
Thanks for your help.
Hey Karsten,
Rail Community
