InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Model coordinates not displaying correctly
3 REPLIES 3
PBriedis
567 Views, 3 Replies
Hi all
Any clues why my model coordinates are showing up as wingdings? I have re-built my model from scratch but same result. My other models are now no longer showing the correct coordinates, suggesting a program issue and not model issue. This problem exists for models which are on my local drive and also in the cloud. This is happening to simple 'clean' models as well as quite complex ones.
I am running IW 360 2016.4
3 REPLIES 3
John_DeLeeuw
in reply to: PBriedis
@PBriedis, that is strange indeed!
What are your your Model Properties concerning Database and UCS settings? Are these the same or different?
John de Leeuw
Senior Consultant
Community Ambassador - Twitter - LinkedIn
I am having the same problem on two different computers. Any fix for this yet?
ocastaneda
What version or versions are you using?
And what is the correlation between the database coordinate system and your model UCS?
Do you know the original coordinate system assigned to the dataset for this particular model? Are the units assigned the same? Metric vs Imperial?
I hope this helps bud!!!
If you find this answer helpful please click the ACCEPT solution and/or the KUDOS button...
Oscar Castaneda
Transportation Designer / P.E.
Infraworks Ambassador
Rail Community
