Model Builder - use with Civil 3D linked projects?
m_kingdon
m_kingdon
Hi all,
We currently don't use Infraworks at my place of work, during lockdown I have decided I will learn everything I can about Infraworks so I can teach my colleagues when I return to the office.
First question:
When should I use the Model Builder and when should I just use the "New" option and specify a co-ordinate system?  Is it best practice to specify the same co-ordinate system used in my Civil 3D drawings, or is LL84 good enough for all situations in Infraworks?
All my Civil 3D projects are based in New Zealand co-ordinate systems (NZGD2000 Meridional Circuits).  I plan on importing corridors, EG and FG surfaces.
Mike Kingdon
Civil 3D Zealot
@m_kingdon , LL84 is not good enough for all design purpose. if coordinate systems are different, Alignment length might be different between Civil 3D and IW. This may not be the result you want.  You will need use new model options.  if you don't have any design data available, then model builder will a good choice since you can get the data very easily.
Hope helps,
Looking foward your feedback about importing corridor to Infraworks.
Frank
Autodesk Infrastructure Product Owner
FrankHuang
Sorry. the former post was from an account which doesn't belong to me. sorry about that. forgot to log out after he logged on my computer for checking his account.
"https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png"
m_kingdon
Thanks.  That pretty much answers my question.  One last thing, is it possible to bring in data from the model builder (LL84) to a new model?
I have a site with limited EG surface data.  I would really like to bring in LL84 data and then overlay my EG surface with draped aerial on top.
Mike Kingdon
Civil 3D Zealot
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @m_kingdon
you could export your Model Builder model to IMX and import this into your own model.
Roads, terrain  and buildings can be carried over that way. For aerial imagery you need to load the Bing Maps again via data sources -add database data source.
Karsten.
Karsten Saenger
