Map missing on navisworks import
helloworld727
helloworld727
I'm importing an FBX from infraworks into Navisworks but the map is missing.
Is there any way to ensure this remains intact or has anyone else encountered this?
Seems as though parts of the mesh become invisible. Image attached.
Thank you
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @helloworld727 ,
this sounds like an issue with the FBX file that was created.
Have you tried to export to FBX from InfraWorks again and does it show the same results in Navisworks?
I also suggest testing with smaller model sizes.
Karsten.
Karsten Saenger
helloworld727
Hi Karsten,
I've tried the above suggestions - unfortunately hasn't made a difference.
Cheers
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @helloworld727 ,
is it possible to share the InfraWorks model?
Let me know if you need a OneDrive folder to upload a zip file of the model.sqlite file and the model.files folder.
Karsten.
Karsten Saenger
helloworld727
Hi Karsten,
Yes I can share, please forward a link.
Cheers.
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @helloworld727 ,
I have opened a support case for you and will send you a link to OneDrive from there.
Karsten.
Karsten Saenger
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @helloworld727 ,
it looks as if a terrain overlay is covering the aerial image.
At the moment, I can't say why nothing is displayed for the terrain overlay. But if you remove it, the FBX export is fine and Navsiworks model shows everything.
Karsten.
Karsten Saenger
