please refer to the below screenshot. I want to remove the exit lane after the diverge section to maintain the lane balancing. proposal is one lane dedicated left, middle lane shared between left and straight and the right lane is for straight going traffic ( after intersection i want to see only two lanes straight ). I tried by replacing the assembly after the nose location but it couldn't give me what I'm expecting to see. any Advise???
Solved by SethHall. Go to Solution.
Hi Bhaskar,
You can select the component, and can then right click and split the component, and delete the component after the junction. You can also use the transitions of the component to control where it starts and end.
I hope that helps,
Harry
Thanks Harry for your reply.
still it doesn't look right. I split the component and deleted it. any thoughts?
My example is not pretty, but maybe something like this would work:
Thanks Hall,
it seems to be working. but now it gives me another problem. Lane marking is not coming on that component road. see the screenshot below.
Glad to help. Unfortunately lane markings do not follow through the intersection objects at this time. Please have a look at this thread for some ideas on how to create your own: https://forums.autodesk.com/t5/infraworks-forum/lane-marking/m-p/7552952
