IW360 Sandbox FBX Export model issue
pding
Message 1 of 9
pding
Hi
  I export my model from IW360 to FBX. There is no problem viewing the result using Autodesk FBX viewer.
  But the file is invalid when I tried to convert it using Autodesk FBX Convertor.
  Same result in Blender..    is there a issue with the FBX file exported by IW360?
   I have attached s sample of the model.thanks
Replies (8)
Message 2 of 9
John_de_Leeuw-NTI
@pding, I'm not sure what you are encountering. Your buildings look good to me in Navisworks.
What are you trying to convert the FBX file into?
John de Leeuw
Senior Consultant
Community Ambassador - Twitter - LinkedIn
Message 3 of 9
pding
trying to convert to collada(dae) ..attached is the error message
but tried to convert to obj too...attached error message
Message 4 of 9
John_de_Leeuw-NTI
@pding, you don't need to convert but can export Collada DAE directly from InfraWorks 360.
Try that and let me know how it goes?
John de Leeuw
Senior Consultant
Message 5 of 9
DarrenP
its possible that converter does not work with infraworks
the last version of the FBX converter was for the 2013 version of FBX
now the fbx file format is up to 2017
do you have 3ds max 2017?
depending on what version of Infraworks your using you may not need to use the FBX converter
DarrenP
Message 6 of 9
pding
That worked..thanks
Message 7 of 9
pding
Hi
   There seems to be texture mapping issue with the 3d models exported by IW360.
   All the texture asscoiated with the model is not showing up and the texture file ext has a extra .jpg attached to it.
   I have attached the model in question in fbx, obj and collada
Message 8 of 9
DarrenP
This is how i see the fbx file in Max 2017
DarrenP
Message 9 of 9
pding
This is what I get instead..
