Hi All
I recently tried to migrate a surface model from Infraworks 2021.2 to Civil 3D 2021, but none of my grading surfaces created in Infraworks shows up in C3D. I can see the proposed surface in the prospector tab of C3D, but it is not showing in the model space. I have changed the surface style to see if that would have an effect but no luck.
All other objects such as the existing ground surface, pipe networks and component roads are visible once the migration to C3D is done. If I export its same model to fbx and open that in Navisworks, I can see the grading surface, but since the "import fbx" functionality has been dropped from C3D, this is not very helpful.
Anyone that can maybe assist me with this problem?
Hi @Anonymous ,
I assume you mean "grading area", right?
These should appear as "AIW proposed ground" in civil 3D after you imported the InfraWorks model.
Can you send some screenshots to better understand your issue?
Karsten.
Yes, I am referring to "grading areas". Please see the screenshots below of what the model should look like (image from Infraworks) and images of what it currently looks like in C3D.
Image of proposed grading area in Infraworks:
Infraworks Model
Image of the " Refine Selection" settings in C3D:
Image of imported Infraworks model in C3D:
Image of "AIW_Proposed_Ground" surface properties:
I hope this makes my original question a bit more clear.
Cheers
Hi @Anonymous ,
thanks for the screenshots.
Did you create the grading areas in InfraWorks or did you load a data source and assigned gradig area as feature class?
There is a difference in behavior if you load the data in Civil 3D depending on how the grading area was created.
If created in InfraWorks, the grading are appears as "Proposed Ground" surface in Civil 3D.
If loaded with data source, the grading area is merged with "Existing Ground". You should see the border of the grading area in the triangulation.
Karsten.
Thanks for the explanation. I have a similar understanding of the different "types" of grading areas.
I have created the grading areas in my model within Infraworks. So if I am correct, they should show up as separate surfaces in C3D?
Cheers
Hi @Anonymous ,
correct, I'd expect to see them in the proposed surfaces.
Karsten.
As you can see @Karsten.Saenger (from the screenshots in my previous post), that is not the case hence the reason for this conversation.
Thanks for your effort in trying to assist. I really appreciate it, but it would seem that this is potentially a bug or a problem with the model itself.
Cheers
Hi @Anonymous ,
I can take a look at your model and try to find an explanation if you want, please let me know.
To share the model, you can either upload it to BIM 360 and get me access it or you could create a zip file of the model.sqlite and model.files folder and upload that single zip file to a shared drive. I can share a OneDrive folder with you if you want.
Karsten.
