- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
"Autodesk Navisworks-based Local Import: Components such as Autodesk Navisworks Manage 2020 or Navisworks Simulate 2020 64-bit are required. To enable Local Import after you have installed Navisworks, you may have to run InfraWorks as an Administrator, which will copy three plugin files to the local Navisworks directory."
We are testing VDI at the office and are experiencing some issues with this.
Does anyone know which 3 plugin files need to be copied and where should they be copied to?
Thanks in advance for your time and help
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
