- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Everyone ! I'm Camelo da Silva Poloni, Manuel. A 23 years old Northern-Eastern Italian Inventor & 3d/CAD Designer.
Today I'm here to ask you Guys for you Luminous and Kind Support ( I Love Autodesk and its Community ). It have been years up to this day, that I've seen the Potential of Autodesk Infraworks in the "Gaming/Simulation" Industry. In Infraworks we can literally import real world DEM/Raster Images data and the program basically autogenerates all the hard work for us. It creates a realistic 3d landscape of a 1:1 real-world scale of terrain. The more detailed the Topographic data is, the more realistic Infraworks generates the 3d model of the terrain. Nowdays the average levels of details you can get here from the Internet are about 30m (#new - the 90m is the old one) of altitude SRTM "satellite/orbital" scannings of Earth.
It's not that Impressive, but it's good enough. I've even managed to get a 10m terrain data, and those are actually very good, but it's rare to find them.
https://www.eorc.jaxa.jp/ALOS/en/aw3d30/index.htm
https://dwtkns.com/srtm30m/
http://tinitaly.pi.ingv.it/download.html <-- the LIDAR scanning / Italian 10m thing.. Which is very Good but must be combined with "sub-dem data" and behave as an overlay because at the "edges" of the national boundaries of italy, this LIDAR data it's harshly CUT.. some people will understand what I'm talking about.
So, let's get back on track.. I've seen the outstanding potential of Infraworks. And I have the need to export the tiles of the terrain generated in it, to several softwares. Like: Zbrush, 3ds Max -> these two for fixes*
And at the end of the day the objective is to export the whole thing to Unreal Engine 4.
This.. is the "texture and detailing" workflow. But there's the other face of the medal that is the "engineering workflow" call it as you better desire, but there's the need to export tiles of the terrain into CIVIL3d first, and then after that I can export the thing to the previous mentioned "texture and detailing workflow".
I know it's complicated stuff, it really is.. I've spent years just to figure out the whole process behind this.
But, now I've find out that a script like the one I have always imagined, actually exists:
https://knowledge.autodesk.com/support/infraworks/learn-explore/caas/sfdcarticles/sfdcarticles/Infra...
I've downloaded it, and tested it.
But it doesn't work.. It gives me an error message saying:
[ERROR] line: 141 : Error: Export3DModel(): Can't create parent folder for C:UsersmanueDesktopA-Infraworks_JS - [ EXPO-TILES ]/tile_0_0.dae.
[ERROR] Error: Export3DModel(): Can't create parent folder for C:UsersmanueDesktopA-Infraworks_JS - [ EXPO-TILES ]/tile_0_0.dae.
Valutazione script: 0.412 secondi
I have already tried to run Autodesk Infraworks with Admin Privileges. But nope.. the script still gives this issue.
I truly need HELP to sort this out. And there's another Request I have !
I'm in need to be able to EXPORT the tiles of the FULL landscape, in different formats of extensions. (not just .dae)
The .IMX one (for Civil3d) and the (.dae or .FBX) are required as well. I know the script already exports in .dae , but if the .fbx option is achievable it would be great !
I Still have to learn JAVA Script. I know how to modify it a bit, but I still have a lot to learn about it.. I've tried to figure out a solution for this issue on the web, but there's nothing too much specific in order to actually help to resolve the issue.
stackoverflow.com/questions/31876640/cant-create-file-because-file-doesnt-exist
*it's not helpful...
Thanks in Advance to All and here's some screenshots ! 🙂
**It's Important to understand, that a LARGE-SCALE (example: 100Km^2 or more) terrain generated in Autodesk Infraworks. It's WAY way too big to be exported at once. You need to have a "NASA Supercomputer" to do that (We're talking about tens of millions of polygons for the full-area // tiles are preferable in order to be optimized first before full "composition").. So.. the only valid solution it's to export the WHOLE Terrain by dividing it into smaller TILES. It's fully possible to do that in Infraworks in a "MANUAL" manner. But.. yeah it takes truly too much time and effort. I need an automated way in order to get the job done easily and quickly. So the Script it's the only way.
TRULY THANKS TO ALL in advance ! :')) :,))
Inv. C.Manuel.
0355AMutc+2CET - 23OCT2019.**EXAMPLE of manual tile EXPORT
**EXAMPLE of manual tile EXPORT**EXAMPLE of manual tile EXPORT
