Infraworks Hardware
Infraworks Hardware
Message 1 of 8
Infraworks Hardware
I would like to run big models on Infraworks and looking at a dedicated machine.
RAM and CPU are a given: the more the better. But what is the answer to GPU? is having a GTX1080 will show me great performance boost? what about an SLI setup?
Does Infraworks take advantage of the GPU?
Many thanks
Replies (7)
Message 2 of 8
Matt__W
Have you seen the system requirements for IW 360 page? Here are a few of my laptop's specs. And I have an NVIDIA Quadro M4000M graphics card.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 3 of 8
Thank you Matt
Allow me to clarify:
I have seen the minimum requirements and my question is not about that, the question is about the GPU and if I buy the top of the line card, will I see benefit with Infraworks? as well, will it be better on an SLI setup?
Coming from Revit, top of the line card does not mean better performance 🙂
cheers
Message 4 of 8
Matt__W
From my personal experience, you don't need a top-notch, super-duper computer to run Infraworks. It handles large data sets very well. I was running it on my previous laptop which only had 16 GB of RAM and a Quadro graphics card. Nowhere near top of the line and it handled my models without any issues. Likewise with my current set up. I should also add that in addition to running Infraworks, I'm also running Revit MEP/Structure (2014-2017), Navisworks, AutoCAD MEP/Civil 3D 2015-2016, 3DS Max, Stingray and Recap.
Matt Wunch
Twitter | LinkedIn
Message 5 of 8
Appreciate your response and taking the time Matt.
I'm after a technical answer from an Autodesk Technical person. Need to understand how the program is taking advantage of the GPU.
Message 6 of 8
Matt__W
Okay. Maybe @Willy_Campbell can help you out with this one. He updated this article a little while ago when I was having problems with IW and my graphics card. Hopefully he'll chime in later.
Matt Wunch
Twitter | LinkedIn
Message 7 of 8
Karsten.Saenger
Autodesk Support
Autodesk Support
Message 8 of 8
Fantastic Karsten
This is what I was looking for, especially the second updated link.
Thank you
