Infraworks failed to create an intersecion.
hamidatut72
Message 1 of 18
hamidatut72
Hi everybody
here I have an issue with creating an intersection in infaworks 2021. since infraworks create its own intersection while 2 roads reached to each other. in my case Infraworks can't create my intersectin or roundabout automatically. any idea's??? (I am not allowed to change my road geometries.) see the pic.
Replies (17)
Message 2 of 18
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @hamidatut72 ,
assuming you don't use imported Civil 3D corridors, it could be that there is too little space for InfraWorks to create that intersection.
Move other roads away and see if the intersection is created.
Also, make sure that the elevation difference between road profiles that are used to create the intersections is not too large.
Bets Regards,
Karsten.
Karsten Saenger
Message 3 of 18
hamidatut72
Thanks For Your Reply.
I Imported The Roads From Civil3d Without Creating My Intersection In Civil
3d. The Elevation Of Interscted Point Is Equal For 3 Of Roads. I Tried To
Removing A Road To See If My Intersection Be Created, Also Not Working. I
Think Infraworks Has Much Limitation About Intersections. I'm Still Stucked
In.
Message 4 of 18
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @hamidatut72 ,
could it be caused by the new workflow with corridor exchange between Civil 3D and InfraWorks?
Basically, if you load a Civil 3D corridor in InfraWorks, it's built and displayed exactly the same as in Civil 3D, but it's static and not editable. If you try to connect another InfraWorks road it won't work, see also InfraWorks Help: To add Autodesk Civil 3D corridors to an InfraWorks model
Karsten.
Karsten Saenger
Message 5 of 18
Eduardo.Soethe
try to change the components
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
Message 6 of 18
hamidatut72
I Tried That. But still not  working. actually I need a Roundabout like below Pic.
Message 7 of 18
Beka_Tchigladze
this type of roundabout will be very hard to do in infraworks and get a decent result try to create it in civil it is more flexible and import it after into infraworks
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
Message 8 of 18
hamidatut72
So, I will Design the roundabout in C3D. But what kind of object should I export&import From C3D to Infraworks to create my exact design?
Message 9 of 18
Beka_Tchigladze
So I will try to make you guess how to do it. I do not think that C3D Roundabout will help you to do this type of roundabout you have to do it manually, with separate alignments to get what you want appropriate assemblies of course and after you will model it if you are skilled in code set styles and others you can assign materials in civil 3d for assembly links after you have to go in infraworks(very important is that Infraworks and C3D must have Same release data 2020 or 2021 whatever) so you can import directly C3d Corridor in Infraworks from Data Sources panel. and walla!
you get a nice Infraworks model if you modify the C3D corridor it will change automatically in infraworks after the refresh the data source.
Here is an option of importing C3D model
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 10 of 18
hamidatut72
I Can Make It Manually. But Some Of Corridor Bowties in The Rounded Corners
Have Appeared That I Can Not Solve That By no Way.
Message 11 of 18
Beka_Tchigladze
can you show us screenshots or something?
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 12 of 18
hamidatut72
The Median corridor can not reach to the selected target in the Pic. And Boewtiese resolve can not solve this
Message 13 of 18
Beka_Tchigladze
can you upload your model?
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 14 of 18
hamidatut72
Sure. But it's a large size file. it took some time. Send me you're Email
Message 15 of 18
Beka_Tchigladze
upload it on Wetransfer and put the link here to download
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 16 of 18
hamidatut72
Message 17 of 18
Beka_Tchigladze
so I modified your assemblies a little bit and create 2 from one as medina 011 median 012 after I add a small tiny fillet in the corner of the grading feature line after I target back to spline baseline you can review the corridor how do I modify.
Here is a modified drawing
https://we.tl/t-KYe4nzLrcJ
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Message 18 of 18
hamidatut72
Thank you Very much. Good help. Now I can design intersections in a much good way.
