Infraworks does not want to Sync with BIM360
dominique.vdwesthuizen
Hi all
my company have recently done our yearly software upgrades to 2024 versions of autodesk software. i went into the autodesk docs folder in infraworks and opened / downloaded my project model as i always do. after i have made changes i hit the sync button, and nothing happens. has anyone experience sync issues. i have the latest updates installed.
tmachado
Hi @dominique.vdwesthuizen ,
Try to use the model cleanup tool and try to sync again, if that doesn't work clone the model with a different name and try to sync.
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Karsten.Saenger
Autodesk Support
Autodesk Support
can you share the latest InfraWorks log files from path %AppData%\Roaming\Autodesk\Autodesk InfraWorks\logs?
The issue you are describing happens very often, if the local cache folder for cloud models is pointing to OneDrive.
The solution in this case is to select a local drive folder as the cache location in the application options.
If a model has some corruption already, the Model Cleanup Tool can reapair it, as @tmachado mentioned.
Karsten.
Karsten Saenger
