InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Infraworks Confiuration Script mapping from csv file
4 REPLIES 4
gleeuwdrent
422 Views, 4 Replies
I am trying to create a configuration script to map shapefile coverages to coverage styles based on the shapefile attributes and a csv file. My csv file has the following structure:
I'm using this script in my configuration file:
function Process(SOURCE, COVERAGES) {
    COVERAGES.EXTERNAL_ID = SOURCE["FeatId"];
    COVERAGES.RULE_STYLE =GetMapping(SOURCE["LAYER"]);
    return true;
function GetMapping(layername)
	var  data = file.ReadFile("C:/Users/XXXX/Documents/Infraworks NLCS mapping.csv");
	var rows = data.split("\n");
	for (var i = 0; i < rows.length; i++)
		var cells = rows[i].split(",");
		if(cells[0] == layername)
		return cells[1];
	return null;
The script is working fine, but the coverage style is not recognized, while the style name is correct:
When I enter the same style in the manual style, the style is correctly mapped:
Any thoughts how to fix this? Or is it a bug in Infraworks?
4 REPLIES 4
andrewofabley
in reply to: gleeuwdrent
I typically do this by having the attributes on the shape file itself, and then employing a style rule.
Is that an option?
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
Matt.Wunch
@gleeuwdrent I wrote a similar script a few years back. It was focused on buildings but can be modified for coverages. Let me know if it helps or if you have any questions about it.
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/update-infraworks-360-data-u...
gleeuwdrent
in reply to: Matt.Wunch
Helllo Matt, thanks for your reply. Your example creates an afterwards mapping: first import your assets and then style them using a scripts. That gives good results, but when you re-import your assets, all modifications will be lost and you have to re run the script. That's not desirable for ease of use.
@gleeuwdrent if you want, you can import the layer AND stylize by script. Here is a sample script to import city furniture type but you can customize by modifying or adding UI to this. Please rename the .txt to .js before running. I always suggest taking a backup of the model before experimenting with a script for just-in-case situations.
Ramesh S
Product Manager - Infrastructure Solutions
Ramesh.Sridharan@autodesk.com
Ramesh Sridharan
Product Manager
Rail Community
