Infraworks 2022 freeze
onarchi
Message 1 of 14
onarchi
Infraworks 2022 freeze during create building!
Replies (13)
Message 2 of 14
onarchi
help me !!
Message 3 of 14
ramesh_sridharan
@onarchi Does this happen consistently or everytime you try to create?
Ramesh S
Product Manager - Infrastructure Solutions
[email protected]
Ramesh Sridharan
Product Manager
Message 4 of 14
onarchi
Thank you for your attention.
This happens every time.
Message 5 of 14
onarchi
This happens everytime I try to create
Message 6 of 14
ramesh_sridharan
@onarchi I tried it on my side and was able to create it without any problem. I am not sure what's going on. Were you able to create any other feature and only buildings giving you trouble? Not sure if anything else running in the background, to make sure were you able to reboot and try, even though this should not be the case.
Ramesh S
[email protected]
Ramesh Sridharan
Product Manager
Message 7 of 14
onarchi
When I try to create building
after about 1 minute appear select draw style
and then i can draw line
but the building is creaded very slowly
Message 8 of 14
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @onarchi ,
it would e interesting to see the full log file from path %appdata%\Autodesk\Autodesk InfraWorks\logs.
There seem to be some errors that relate to missing styles. Maybe that causes a performance issue.
It could also be related to a general database issue on your computer or graphics settings or hardware.
Karsten.
Karsten Saenger
Message 9 of 14
onarchi
I solved the problem.
The problem was a program called Microsoft PowerToys.
When I uninstall this program, it works normally.
Thank you for your interest in my problem.
Message 10 of 14
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @onarchi ,
interesting, thanks for sharing the solution.
Karsten.
Karsten Saenger
Message 11 of 14
onarchi
Oculus rift also interferes with normal operation.
It works well when I remove the USB for oculus rift.
Please let me know if there is a way to not run oculus rift when running infraworks.
Thank you...
Message 12 of 14
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @onarchi ,
unfortunately, no current Oculus device and driver are supported for InfraWorks.
The last supported device got unsupported by Oculus back in 2018.
Here is the last Information that is available about that:
https://knowledge.autodesk.com/article/Oculus-Rift-and-Infraworks-360
Karsten.
Karsten Saenger
Message 13 of 14
muratozmen
Hi Onarchi
I have the same problem and haven't got powertoys. there should be a different solution. Why did you think powertoys is the cause. Maybe it helps me to find a solution for myself.
Regards
Message 14 of 14
muratozmen
Mine is Grammarly, when I stop grammarly , IW works properly.
I would suggest anyone facing the same issue try closing softwares one by one until they find a solution.
