Infraworks 2015 -- road design
danielmn81
danielmn81
Is the road design module that is in infraworks 360 available in infraworks 2015?
[email protected]
Eduardo.Soethe
@danielmn81
no
Just in Infraworks 360.
Your infraworks 2015 can upload to 360?
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
danielmn81
What do you mean that my infraworks 2015 can upload to infraworks 360?
Can you use the model builder function in Infraworks 2015?
My company is not allowed to use any of the 360 options.
from my IT department
"as cloud-based applications are restricted, ....and the Fed security compliance yet.
Our ELA allow us access to most all of the Autodesk products. The 360 versions are not under that"
But from that version on, everything is 360 @danielmn81.
danielmn81
so there is no infraworks 2017 then.
danielmn81
I see thank you that is what i wanted to know definitively.
Thank you.
When I asked the sales staff they kept side stepping that answer.
