Infrawork to VR Engine
paulobelesa
paulobelesa
Hi, I wonder if Infraworks could export the model to  Unreal Engine or to Unity, due to the fact that AD is discontinuing Stingray (bad idea).
Also the rival from Esri is doing it, AD must keep up with VR trand.
Also model texture should be exported as PNG or  JPG.
Todd_Rogers
This is the idea station. This should be posted in the InfraWorks forum.
And yes, you can export the model to Unreal or Unity using the FBX export option.
@Discussion_Admin
Todd Rogers
Civil Administration
Todd_Rogers
Also, ESRI is no longer a rival of Autodesk. See article below...
http://www.esri.com/esri-news/releases/17-4qtr/autodesk-and-esri-partnering-to-advance-infrastructur...
Todd Rogers
tony1978
Though stingray is going away, have you tried 3ds Max Interactive?  Check out these helpful links.
https://area.autodesk.com/blogs/the-3ds-max-blog/bruno-landry-talks-vr-in-3ds-max/
https://area.autodesk.com/blogs/max-station/3ds-max-interactive-2-0-and-revit-live-2-0-are-live/
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
roskirko
That is fine Tony as long as there is a well written workflow for taking Infraworks models over to 3ds Interactive to "bake" the model so that it is ready for a VR experience, just as that in Stingray.
The one workflow I use for using Stingray with Infraworks came from AU 2017 and is attached
Geographic Information Systems
Fanshawe College
Todd_Rogers
It's the exact thing as Stingray.
Todd Rogers
roskirko
Thanks Todd.
It is good to know that Stingray has simply been renamed and/or re-packaged.
Fanshawe College
