OK so here's the deal.
I teach everyone via CADLearning how to use this software and I'm actually recording the lessons on File Importing today and Monday.
The exercise files i use are about 4 years old and have worked consistently until IW 2018.0. Now when I import in certain files like the SDF file they are not translating to any coordinate system, let alone showing up. I've attached a screen shot of what I get after I 1. Import the SDF file; 2. Configure the file; 3. Select and Zoom To Selected on the file from the Data sources panel. I should be viewing 3 lakes, large bodies of water. Instead I get NOTHING!!
I also tried importing and SDF of buildings and again like the lakes, nothing appears.
I've gone so far as to start a new model and only import the file in and you can see what I get on the attached.
In the configuration dialog, I set what "type" of file it is Water bodies, buildings, etc. I set a style for the file type that's appropriate, I make sure that on the Source tab the file is set to "drape" and I select Clip to Model extents. Even without Clip to Model extents selected what is attached is what i'm getting ever time I import in an SDF file.
Now a few versions back in 2016, I had a similar issue with importing SID imagry files. Back then I just change the coordinate system of the file and it would work.
I tried changing the SDF file coordinate system and it did nothing.
So is there a bug that no one knows about yet when importing in SDF files? If so I need to know as I have 2 lessons on this that I can't record if there is.
If there is not than how do I fix this?
Turning off layers does not help at all. As you can see what is attached is simply bringing in only that file into a brand new project.
Heidi B.
