Importing non geo-located Revit
rade_tomovic
rade_tomovic
Is there a way to import non geo-located Revit file into geo-located InfraWorks model, created with Model Builder? I want to place some Revit model to analyze views, but I can't achieve that, my model is not visible, but it is loaded according to InfraWorks.
Matt__W
Try using the INTERACTIVE PLACING option and set the model's coordinates to CENTER 2D (0,0,0).
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Willy_Campbell
Hi @rade_tomovic,
@Matt__W's reply is your best bet. There are other options that give you similar results in that same dialogue, but will not get you as close depending on the model extents.
The reason you do not see the Revit model when IW says it is imported; In Revit, the model base point is typically 0,0, and your IW model is using a real world coordinate system. These typically tun into the millions. If you go to Application Options [by your name/pic]> View tab> check Automatic zoom to selection> Right click-select features on your model in the Data Sources panel, you will be taken to where your Revit model is found.
Willy Campbell
