InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Importing a Civil 3D model in InfraWorks
2 REPLIES 2
mats_bervoets
294 Views, 2 Replies
Is there a possibility to import a Civil 3D drawing (see screenshot) in InfraWorks?  I haven't found the correct solution yet. What is the right way to model (roads, parkings, stream,... ) using the lines and cogo-points of the Civil 3D drawing?
2 REPLIES 2
Hello @mats_bervoets ,
to import a Civil 3D DWG into InfraWorks, the drawing must contain Civil objects, such as corridors, surfaces, alignments, etc.
Please take a look at the help content to get more information:
Autodesk Civil 3D Help | Exchanging Data with Autodesk InfraWorks
Karsten.
Karsten Saenger
Once the Civil 3D objects are export such as a surface, you can export closed polygons as Shape (shp) file for Coverage Areas. This will add materials on the areas such as sidewalks, pavement area, grass areas, and so on.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Rail Community
