It is unfortunately that IW only accept centerline alignmetns from civl3d. How can i transfer such alignment to Infa then?
Solved by VincentSheehan. Go to Solution.
Have you tried to export the Civil 3D objects to a Land XML format to import into Infraworks?
Thank for such a simple solution Vincent but still i hope IW will soon allow to transfer direct offset alginment from civil3d so user dont need to managing too many import source file
