InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Импорт из Civil 3D в Infraworks
3 REPLIES 3
303 Views, 3 Replies
Создал поверхность и автомобильную дорогу в Civil 3D, импортировал в IMX, при импорте IMX в Infraworks выскакивает ошибка с системой координат. Систему координат установил в Civil 3d и такую же выбрал в InfraworksОшибка.PNG
3 REPLIES 3
Karsten.Saenger
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
can you change the product language to English in the application options (top right), restart InfraWorks and create the error message again?
It will help much better to exactly understand the error.
Else, the InfraWorks log files might give a hint about the details of the error - %appdata%\Autodesk\Autodesk InfraWorks\logs
What database coordinate system does your InfraWorks model use?
Usually, the IMX file carries coordinate system information. So, there shouldn't be a need to assign anything.
I understand you are using your own custom coordinate system, is that correct? If yes, there could be an issue with translation to WGS84 (LL84) if the transformation does not work correctly.
Karsten.
Karsten Saenger
Hi @Anonymous ,
Karsten.
Karsten Saenger
in reply to: Karsten.Saenger
Karsten.Saenger
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
thanks for sending the error message in English language.
Could you please provide the Infraworks log files from %appdata%\Autodesk\Autodesk InfraWorks\logs ?
Please confirm if you are using a custom coordinate system.
What database coordinate system does your InfraWorks model have?
In Civil 3D, when you type GEOMAP, is the Bing aerial imagery loaded correctly?
Karsten.
Karsten Saenger
Hi @Anonymous ,
Karsten.
Karsten Saenger
Rail Community
