Hi all,
I'm currently using InfraWorks to design a new access road which joins on to an existing road.
I have watched some videos and have noticed that when you model two roads and join them together, it creates a intersection between the two where you are then able to modify the radius of the corners to suit your requirements.
But for some reason when i join my proposed road to an existing i don't get a separate junction feature and instead it just joins the two together. So i'm then unable to modify the radius'.
I'm not sure if i need to create an intersection type or something similar prior to me joining the roads together? If so how would i go about doing this?
Thanks in advance.
Solved by SethHall. Go to Solution.
If you want an intersection object to be created, you need to convert the existing road to a Component Road. Just select the existing road, right click and select "convert to component road". You should be able to create an intersection after this is done.
