InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
How do I create sidewalk ramps and driveways in infraworks?
4 REPLIES 4
1167 Views, 4 Replies
I have a couple of models that I am trying to create sidewalk ramps and driveways in but am not having much luck.
Does anyone know if this can be done and how.
4 REPLIES 4
JasonArtley
There's not really an easy way, but it is possible. Here's a couple tricks I've used in the past to make it look like a ramp/driveway is in my model.
Method 1: Use component roads, split the curb and leave a gap. Then use transition in/out to make a curb transition. Then use a land area to make the driveway. It takes a little adjustment but can make a decent ramp.
Method 2: Same as above, but leave the gap without the transitions. Use sketchup/formit/etc to model a ramp or driveway and drop it into the gap you made.
Method 1 example:
Hi @Anonymous ,
there is a possibility to model these sidewalk ramps in Civil 3D with a Dynamo script, see https://www.youtube.com/watch?time_continue=372&v=uqEg7XbvnL4 (from minute 36:30):
2019-11-04 10_02_27-[Webinar] Infrastructure Design Automation with Dynamo for Civil 3D - YouTube.png
You could load the results into InfraWorks for visualisation.
Karsten.
Karsten Saenger
h.malgarezi
in reply to: JasonArtley
It's not possible to use transitions (in/out) using the default curb/curb&gutter element for component roads.
dean_petersen
in reply to: h.malgarezi
It can still be done if you make the kerb shape you want out of one or more Generic Shape components.
Rail Community
