Help?
Best Regards,
Devrim Ozerdinc
P.S. I dropped a PNG capture of the loading screen. It's been giving me an error message all day yesterday.
P.P.S. Confirmed: error message occurs today as well.
Solved by ramesh_sridharan. Go to Solution.
@Anonymous Can you please add little bit more details like what is your point cloud size, are you having one RCS or multiple RCS with 1 RCP, is processing still continue giving you the error message to you get the error before or after processing is run?
Thank you,
First thing I did was download the tutorial's sample zip file.
After extraction, the folder is about 12-13 GB (12.4GB).
The RCP file itself is 800KB (748KB).
I load the RCP file so that it appears on the map, but processing for the Point Cloud Terrain fails every time.
On the attached screenshot the "Start Processing" option never completes without an error.
Devrim
P.S. If I don't hear from you today, have a great weekend.
Do you have link to that tutorial for me to check it out?
Thanks again,
The link: https://customersuccess.autodesk.com/course?id=320
Devrim
Excuse me!
I found a work-around. Steps 6-11 on page (31%) of the tutorial can be omitted entirely.
Devrim Ozerdinc
For clarification, these are the steps which seem to cause the issue, on page~4:
I'm okay with omitting this processing step, because Infraworks let's me classify the points regardless of running through it.
Devrim
@Anonymous It sounds like the sample data provided already got the classification done and hence you might not need to run it again. But in a real project, if you got some point cloud data you can use those steps to generate terrain. I am glad you can move on with your course/tutorial but I will reach out to the course administrator to make sure we make the necessary update if needed.
