InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Haunched Concrete Bridge Girder in Infraworks
1 REPLY 1
oliverkisera
476 Views, 1 Reply
Hello friends, Ive tried ways to make a haunch concrete parametric bridge girder in Infraworks but to no suceess, Im using Revit 2024 and it allows use of rfa families for parametric girders in Infraworks, which is really nice, bu the girder modelling in revit is only limited to cross-section only. I have attached a pic showing the haunch a long the longitudinal length of the girder, so the girder looks more like its curving along the longitudinal length, is it possible to model this in Revit and import into Infraworks, I will really appreciate your help, thanks
1 REPLY 1
ara.ashikian
in reply to: oliverkisera
In InfraWorks, when a bridge is selected, the next selection click on a span will select all the girders in that group. If you click again, it will select that specific girder.  By default, unless you manually switched a girder to use a more complex 3D girder option, the girders are created in InfraWorks by extruding or lofting the geometry of the girder cross section.  These cross sections can be created as Inventor parts or Revit families and can expose various parameters to control their dimensions. By default, a small blue plane is shown at the ends of the girder.  If you change the girder parameters at this stage, it will affect the entire girder. However, you can also click a select one of these planes and they will turn orange.  Now, you would be changing dimensions of the girder at that location.  With the mini toolbar that shows up, you can also click the + button and add more locations (called slices) along the girder and change parameter values at those locations.  Btw, you can also use the send to spreadsheet workflow (from the context menu when the bridge is selected) to then make changes to girder slice parameters or even add or delete slices in Excel, to then save the spreadsheet and from the context menu in InfraWorks, select to update the bridge from the spreadsheet.
In the images below, I show how I selected a girder (I hid the others for clarity) and then, selected the slice at the near end and changed the Depth parameter to from 14ft to 16 ft and then in the 3rd image, showing how after adding a new slice at a desired location along the girder, I changed its Depth parameter to 12ft.
Let me know if this clarifies this issue.
-Ara Ashikian, P.Eng.
PM InfraWorks, Bridges / Civil Structures
PM Bridges / Civil Structures
Rail Community
