Ghost modeles driving around
tomaz.pikovnikLEMYJ
tomaz.pikovnikLEMYJ
Hei,
we have created train in SketchUp pasted pictures on faces and exported it .max file to import it to 3ds max (ver. 2021) to make animation, in 3ds max everything looks ok, but when we put animation in InfraWorks everything we get in ghost trains (see picture), we would like that the models look like in 3ds max (see picture).
Tomaž
andrewofabley
@tomaz.pikovnikLEMYJ
I believe you can get around this by using the 3ds MAX scene converter to change the materials to 'Standard Materials' before export.
This may fix your issue.
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
Todd_Rogers
I have attached the file you need. Download and save it. Extract the zip file. Once extracted, drag and drop it into your 3ds Max model, then re-export it.
Todd Rogers
Infrastructure Administration
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @tomaz.pikovnikLEMYJ ,
also, make sure you have switched on "show backfaces" in the application options:
Karsten.
Karsten Saenger
tomaz.pikovnikLEMYJ
is this code compatible with 3ds max 2021 and Infraworks 2021, because it doesnt work, I still have the same problem
Todd_Rogers
Click on your model, right-click and select Properties. In Properties, change Model Split to True.
Todd Rogers
tomaz.pikovnikLEMYJ
Open dae. file in notepad and change transparency
If the transparency in your 3ds Max materials is set to 1, you can manually edit the .DAE file by replacing
<float sid="transparency">0.000000</float> with  <float sid="transparency">1.000000</float>.
