From Infraworks to Navisworks
Message 1 of 12
Hello everyone,
When I export the model from Infra to Navis, all the data and the characteristics assigned (for roads, bridges...) are being lost. How can i do for?
Thank you
Miky
Replies (11)
Message 2 of 12
Hello @Anonymous,
can you explain your workflow?
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
Message 3 of 12
Hi @Anonymous
when i "Export 3D model" i have these information inside Navis. What can i do for?
Message 4 of 12
Matt__W
Unfortunately, you're not going to get much data from your FBX. InfraWorks 360 doesn't export any useful data in the FBX file. If this is something you'd like to see implemented in a future release then I highly recommend you voting up this idea in the InfraWorks Ideas forum@Eric_Chappell 's update for that idea back in July says that it's not currently being considered but will be kept on the list for future consideration (providing there's enough interest in this feature from the InfraWorks community).
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 5 of 12
elliott.rosenfeld
Hi Miky,
Are you able to share your InfraWorks project with me to test this out? You can email me at elliott.rosenfeld(at)Autodesk.com
Principal Specialist, Infrastructure
Message 6 of 12
Hi @Matt__W
thanks for the infos.
I hope that in the future the implementation is possible because the interaction among the programs is very important. i have loaded my idea on the forum.
Michele
Message 7 of 12
Hi @elliott.rosenfeld
I'm sorry but I can not .... Company Policy..Smiley Sad.
do you have any idea for "to turn" the problem?
Michele
Message 8 of 12
Hi @Anonymous,
sorry for late response, unluckily there is no way around that. Not now. There is no information that could be taken out.
Follow what @Matt__W said.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Message 9 of 12
Hi Elliot,
Would be great if the development team considers this development again:)
Message 10 of 12
Hi Matt. Do you find any solution to this problem?
When I export FBX file from infraworks to navisworks, all the data and the characteristics assigned (for roads, bridges...) are being lost!
This objects necessary for create 4d and 5d BIM projects.
I use infraworks and navisworks 2020!!!
Best regard
Amir
Message 11 of 12
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
this situation hasn't changed. FBX is "just" geometry and no attributes.
I am wondering if your attributes make the way to Civil 3D if you open your model there. From Civil 3D you could export as 3D solids with attached attributes.
Problem is, that InfraWorks is a database and data sources use certain schema tables. When you convert to geometry (FBX) the schema cannot (?) or is not attached to an object/file.
Karsten.
Karsten Saenger
Message 12 of 12
I have the same problem. I want to use the infraworks model in an other software but the project structure and every data and the characteristics assigned are being lost.. Is there now any way about civil 3D to get an ifc or something else to work with?
Thank you!
Best regards
Annika
