Hi, I have tried exporting this 5x5km city model terrain for a bit now, for example leaving the FBX export on for the night.
It looks like this after the night: doing something but having not started the write process. CPU at 20%. I have i7-7700HQ with 6 mb L2 cache and 32Gb DDR4.
The terrain has some black magic going on with elevations, water areas and coverages, and I am using a 0,25m - 2m generalization to have it regenerate in a reasonable time when working.
Do you think there is an issue and I should not try and wait for some more days with the export? This is try number ten or something... Is there a problem with FBX, should I test DAE?
Solved by Karsten.Saenger. Go to Solution.
Hi @Anonymous ,
what's your goal to export a terrain of that size as FBX file?
A 25cm ground resolution will result in a 400.000.000 quads = 800.000.000 triangles file...if I am not wrong.
That sounds like a very large FBX file, don't know if that even works.
Karsten.
Hi @Anonymous ,
Karsten.
