Recently I have seen a question that should help me with extending the categories in Infraworks.
Looking through post and comments I have not found solution for me.
I need to add "Visibile" button in front of every feature set in Surface Layer category.
I tried to edit ModelExplorer.json file which is in Modelname.files folder.
"Category_Surface Layers": {
"selectable": true,
"lod": false,
"name": "Surface Layers",
"iconPath": ":/Icons/Common/folder.ico",
"Color": {
"name": "#0000ff",
"alpha": 255
"Feature_USER_A_LANDSCAPING_OUT": {
"className": "USER_A_LANDSCAPING_OUT",
"selectable": true,
"visible": false,
"iconPath": ":/Icons/Common/coverage_32.png",
"Color": {
"name": "#993388",
"alpha": 255
Here I took a string "visible": false, from default parameters of "Category_Surface Layers" and move it to "Feature_USER_A_LANDSCAPING_OUT".
When I load my model again the file was re-written, however, I saved ModelConfig file. I also tried to mark this file as "Read only" but it did not help.
