Exporting fbx
Exporting fbx
BIMadmin
Message 1 of 8
Exporting fbx
BIMadmin
Hello guys,
The problem herer is that we are trying to export to fbx and it is taking ages and finally need to cancel the task.
My PC is quiite powerful, I wonder if there is any kind of limitation in terms of scene size and what timing is normal depending on the scene size.
Any comments will be really appreciated.
Replies (7)
Message 2 of 8
Hi @BIMadmin,
have you tried exporting a small portion? Which version are you using btw?
There have been quite some discussions about this topic.
http://forums.autodesk.com/t5/infraworks-360-forum/problem-with-export-fbx/m-p/6741450/highlight/tru...
and more
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Want to present in Infraworks? Vote this up!
Message 3 of 8
BIMadmin
I have tried a very small portion and does work.
Big scenes, for master planning the software cannot cope.
Message 4 of 8
Hi @BIMadmin,
there are also different formats that may work better for you.
Check out .DAE or .OBJ
https://knowledge.autodesk.com/support/infraworks-360/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Message 5 of 8
BIMadmin
Using last version.
I have tried obj and dae and it is a lot quicker!!!
Can you explain us why is that?
Message 7 of 8
Carrillof
Hello
I recommend you send it in .OBJ in case the problem continues, you can try reinstalling Infraworks,
Message 8 of 8
Hi @BIMadmin,
Another way can be to export smaller portion of FBX and combine them in the other software.
Or you can follow the indication of @Carrillof, he knows a lot about IW.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
