InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Export roads to FBX
4 REPLIES 4
andre.normann
1023 Views, 4 Replies
Export roads to FBX
I want to export roads from Infraworks to FBX. It works for one project in the past, but for my new project it want work anymore. I select export to multiple files, but there is no option for exporting roads or railways.
Best regards,
André
4 REPLIES 4
Hi Andre,
What exactly doesn't work, could you add some more details?
Roads can be brought to Civil 3D very comfortable if that helps.
Markus
Markus Briglmeir, Product Manager BIM 360 Design Collaboration
I want to export roads to FBX to use them in a 3rdParty visualization software. I am not using Civil3D.
As you can see, there is no road feature in the target files list.
Best regards,
André
If I can not get a solution here, what is the best way to get in contact with Autodesk? I am under an active subscription if it helps.
Best regards,
André
I got a solution. Roads are part of the ground in the fbx export dialog. You simply have to export the ground.
This solution comes from my reseller Systemhaus Maraite-Kratzenberg GmbH & Co. KG. Thank you very much!
Best regards,
André
Rail Community
